How to get a COM port identifier?
@popol21 wrote:
I have a problem I thought would be easily solved. But finally I can't find the solution myself.
Under Windows (XP), if I go into the Device Manager, I can see the list of my hardware, including the COM ports. I can see there an "identifier" of the port. For example, if I plug an USB to RS-232 converter (FTDI), I can see its name.
How can I have access to this identifier under LabVIEW?
Thank you in advance for your answer.
You see the (FTDI) name in the device manager because of the FTDI driver....
To access these informations I would call  the FTDI dll functions with labview  (like KC said)
But first would digg into the VISA properties,but I think you already looked into it .... (sorry currently no FTDI serial device nearby...)
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 15
(2,185 Views)
Ok, thank you KC and Henrik. I will follow your suggestion.
Message 12 of 15
(2,176 Views)
Have you tried to query the name using a VISA Property Node? Try the Interface Information->Interface Description property and see if it gives you what you are looking for.
-Jason S.
Message 13 of 15
(2,145 Views)
@ popol21: Have you successfully tried it with the dll? You can find LabVIEW examples at FTDI's.
The workflow would be:
1. get a full list of FTDI devices (dll)
2. search it for your desired device description (LV)
1&2: If you can ensure there's only one such device: Open it by description (dll) (FT_Open_Device_By_Description.vi)
3. get the COM port number of the device with that description (dll) (FT_Get_COM_Port_Number.vi)
4. get the ASRL... identifier according to the COM port number (VISA/LV)
4. open the COM port with a string ("COM " + number) as the resource (VISA) (you will see a coercion dot!)
5. do your regular communication with the VISA resource out (of VISAopen)
I hope this helps everyone using FTDIs! Smiley Happy
Message 14 of 15
(2,009 Views)
Yes, I achieved to do it. Anyway, thank you for your answer. Indeed, if people are looking for FTDI identifier, follow the above instructions.
Thank you again.
Message 15 of 15
(1,999 Views)
