How to programming for GPIB Primary Address 0 and 31?
Hello. How to programming for GPIB Primary Address 0 and 31?
(3,979 Views)
I programmed GPIB primary address 0 the same way as any other valid primary address. Manuals say that the valid range is 0 to 30.
(3,979 Views)
Make sure no other instruments are at addresses 0 and 31. National Instruments GPIB controllers default to primary address 0, so if you want to use an instrument at primary address 0, you should change the address or your controller. You can do this by using the ibpad function.
NI-488.2 Function Reference Manual for Windows
(3,979 Views)
Address 31 is invalid. It is reserved for the UNTalk and UNListen commands. It is generally preferable to create a device that does not use addresses 0 or 7 since those are common controller addresses.
(3,979 Views)
