Pushpa,
You should use VIs from the File I/O palette to save the data to your hard disk.
You can also look into /examples/file VIs for additional help on how to save to different file types.
In the feature, you should post the pure LabVIEW related questions to the LabVIEW forum.
Zvezdana S.
