How to set Yokogawa WT210 Display
I am newer to LV and have just perchased the labview version 2015 and would like to lock  display Yokogawa  WT210
I need :
Chanel A : Voltage (V)
Chanel B : Power Factor(PF)
Chanel C : Current (A)
But when I command measure, WT 200 display set to
Chanel B : Current (A)
Chanel C : Power (W)
Ai
(3,168 Views)
Changing "Element" like below didn't work?
Certified LabVIEW Developer
GCentral
(3,151 Views)
Emboar.
I'm sorry.
I need remote set WT210 display in picture below.
Changing "Element" .It's not work.
Thank you for your help.
(3,142 Views)
Accepted by Hanna-ai
User's Manual
See page 14-22 on the manual.
It seems that you can achieve your request by sending
DISPLAY1:FUNCTION? -> :DISPLAY1:FUNCTION V
command through VISA write function.
Try it out.
GCentral
(3,132 Views)
Dear Emboar
Thanks so much. It's really success.
(3,116 Views)
