How to use labview to control a Newmark linear stage?
Any one can give me some implication on how to control a Newmark NLE-50-A XY linear stage with a NSC-M2-E stepper motor controller, this stage uses a RS 232 cable connected to the PC and it comes along with a manual with commands. I have never done serious communications using labview, so if any one can post a sample program, that would be very helpful.
Thanks.
John
(4,087 Views)
You need to look at the manual to see what the commands are, and then you can use the Instrument I/O Assistant to get you started at a very high level. For more serious programming you'll need to delve into using the VISA functions. Examples ship with LabVIEW. Just search for "serial". I would also suggest perusing this article: Instrument Control in LabVIEW Tutorial.
(4,078 Views)
