I am getting an linker error LNK2001 : unresolved symbol _main while compiling Microsoft c code
I am writng a simple application in C language for communicating with GPIB. when I compile the c file I am getting a linker error
LIBC.lib(ctr0.obj): LNK2001 error: unresolved sysmbol _main
I compile the application in the dos window using the command
cl gpibApplication.c gpib-32.obj.
Could anyone tell me how to remove this error
(3,400 Views)
Hello-
It sounds like the main function is missing from the gpibApplication.c file. Be sure that the following function is somewhere in the code:
int main (int argc, char *argv[])
Also, note that this function is case sensitive, so be sure main is not capitalized.
Randy Solomonson
Application Engineer
(3,400 Views)
