I am not able to read the register content of the NAT 9914
I am interfacing the ARM7 uC & the NAT 9914 ,for D 0-7 is provided via 3.3-5V converter.
The CE,WE Dbin & the RS0-2 is provided directly to the NAT 9914.
I am following the sequence
For setting the
1.RS0-2
Then pulling the CE.
then Pulling the WE (in write cycle)
Then placing the data in D0-7 as provided in the timing dia in the NAT 9914's datasheet.
I have reffered to the reference manual,Datasheet & AN110.
I am follwing all the steps for initialization i have attached my hardware schematic & the program (in Embedded C).
You can run the program in keiluVision 3.
Tell me if any more pins need the buffer in the hardware.
Tell me if i am missing any steps.
When I am trying to read the RDISR0
I am strucked at this point so tell me if i am doing any mistake
I am attaching the Hardwarre schematic & the Program in txt format.
When i am executing the program i am having low on D0-7 the pin of the NAT9914
Message 1 of 1
(2,881 Views)
