PCI-GPIB communicating with SR245
I have a PCI-GPIB card and I am having problems communicating with the SR245.
  • I am using Windows XP, LabVIEW 2010 service pack 1, GPIB driver version 2.8 (newest one found on NI).
  • I am not able to GPIB WRITE and returns an error code "6" (timeout error EABO).
  • I've triple checked the appropriate terminal commands (mode 3) and have also tried all the possible combinations just in case.
  • Using the same GPIB card, I am able to communicate with other devices without problems so I have ruled out the possibility of a bad GPIB card.
  • Using another computer running Windows 98, I can also communicate with the SR245 with the SAME cable so I've ruled out the possibility of a faulty SR245 and cable length problem.
I have checked and read all the forums and was not able to find a solution. My SR245 is less than 6 months old so I don't think the solution using the 270 pF capacitor applies to my problem. Using Measurement and Automation, I can see the device with its respective GPIB address. When I try communicating with it, I get the EABO error.
I would appreciate any help. I will try using a shorter cable length tomorrow as well. Thanks in advance.
(3,288 Views)
fixed the problem.
seems like trying to communicate with MAX messed up the SR245, changing the GPIB address solved the problem. I opened up MAX again to see if it was simply because of a GPIB address conflict with another device but got the same error and it stopped working again. Changing the GPIB address of the SR245 solved the problem again and now I am forbidding myself in opening MAX ever again.
Think tank, Thunk!
(3,282 Views)
