I am using RsSpecAn Driver to get the sectrum on My PC using labview, Gpib after running the program i am getting errors like-113.Undefined header ;:TRAC:MODE MAXH"0" No error
hello Everyone,
 I am using RsSpecAn Driver to get the frequency sectrum of Spectrum Analyzer(from R&S FSP) on My PC using labview 8.5.1, Gpib 82357B. After running the program i am getting errors like-113.Undefined header ;:TRAC:MODE MAXH"0" No error
And  such errors for all header 50 ohm imp etc...
Thanks in Advance
Message 1 of 9
(4,839 Views)
Can you publish you vi.
I used the same (downloaded from R&S) and got no errors
greetings from the Netherlands
Message 2 of 9
(4,820 Views)
Thanks so much... I am attaching my .vi file.. I wanted to see spectrum which i have saved as .txt file. Then i will open it in spreedsheet and final result i want on excel. But my .txt file is not getting create. errors to save the file.
Once again Thanks so much...
certain values:
Ref Level 30.E+0
sweep coupling : Sweep time
Stop freq:20E6
start freq:0
Coupling value:4E-3
Ref Level Offset 50E-3
Attenuation:10
Input Imp:50
Amplitude unit:dbm
Pallavi
Message 3 of 9
(4,804 Views)
One thing is that the the VISA Resource input of the Store Trace to File function is not connected. It looks like it is but it goes under the function to the close without actually being wired.
Message 4 of 9
(4,802 Views)
Thanks so much... but i discovered that... I connected but still i am not able to save.txt file... again i am reattaching it... -250 mass storage error is coming...
Thanks so much... If u program is similar kind can u post it...
Message 5 of 9
(4,785 Views)
maybe a stupid question but do you still have a floppydrive on your system and a floppy inside?
I saw the filename was a:\test.txt
Message 6 of 9
(4,776 Views)
No i dont have nor i am using it... its C:\\test.txt
Message 7 of 9
(4,771 Views)
why the double slash?
and why is it not the default in your first program?
Message 8 of 9
(4,761 Views)
 It was written like that by default. Then i changed to single slash.... Can u tell me where i am going wrong. I should see the graph as a text file or excel file.
thanks so much...
Message 9 of 9
(4,745 Views)
