OpenSuse 11.1 64Bit and NI-488.2 Installation Problems GCC
Hi, i have 2 Questions
1:  I read the  KnowledgeBase etry " NI-KAL Fails to Load When I Have Greater Than 4GB of RAM "
     Do this problem still exist in the new version of NI-KAL 1.10 ? Because my system have 6GB RAM.
2:
I try to install the NI-488.2 on the OpenSuse 11.1 64bit with the Kernel linux-2.6.27.29-0.1.
I use the NI-488.2 2.5 Beta 64 Bit Driver.
After the sh ./INSTALL i get this error:
Checking required install tools...
Checking installer tool versions...
rpm        4.4.2.3 can be used with a default installation path
tar        1.20
Checking dependencies...
glibc      2.9
Unpacking install files to /tmp/NI4882-2.5.4b1.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to    *
* compile the currently running kernel.  This can cause unpredictable         *
* behavior in kernel drivers and should be fixed.                             *
* gcc version: Linux)                                                          *
* kernel compiled with: 4.3.2                                                 *
I cheked the Version of the GCC with gcc -v and its the same Version
gcc version 4.3.2 [gcc-4_3-branch revision 141291] (SUSE Linux)
I tryed the solution here on the site. But it doesn help to edit the installerUtility.sh
I just get annother GCC error.
What else can I try to finish the installation ?
Someone gave me the tip to install the NI-KAL 1.10 first and then install 488.2
Do I have to install it with the original installerUtility.sh or the edited ?
(3,959 Views)
this thread was answered in the Linux Community
best regards
Alexander
(3,937 Views)
Hi Iwes
there is also an thread that can help you to install the GPIB driver on SUSE 11.1
i hope this helps
best regards
Alexander
(3,934 Views)
