10-23-2009 03:20 AM
Hi, i have 2 Questions
1: I read the KnowledgeBase etry " NI-KAL Fails to Load When I Have Greater Than 4GB of RAM "
Do this problem still exist in the new version of NI-KAL 1.10 ? Because my system have 6GB RAM.
2:
I try to install the NI-488.2 on the OpenSuse 11.1 64bit with the Kernel linux-2.6.27.29-0.1.
I use the NI-488.2 2.5 Beta 64 Bit Driver.
After the sh ./INSTALL i get this error:
Checking required install tools...
Checking installer tool versions...
rpm 4.4.2.3 can be used with a default installation path
tar 1.20
Checking dependencies...
glibc 2.9
Unpacking install files to /tmp/NI4882-2.5.4b1.install...
******************************** ERROR ****************************************
* The version of gcc in the path does not match the version of gcc used to *
* compile the currently running kernel. This can cause unpredictable *
* behavior in kernel drivers and should be fixed. *
* gcc version: Linux) *
* kernel compiled with: 4.3.2 *
I cheked the Version of the GCC with gcc -v and its the same Version
gcc version 4.3.2 [gcc-4_3-branch revision 141291] (SUSE Linux)
I tryed the solution here on the site. But it doesn help to edit the installerUtility.sh
I just get annother GCC error.
What else can I try to finish the installation ?
Someone gave me the tip to install the NI-KAL 1.10 first and then install 488.2
Do I have to install it with the original installerUtility.sh or the edited ?
10-26-2009 04:13 AM
10-26-2009 04:28 AM
Hi Iwes
there is also an thread that can help you to install the GPIB driver on SUSE 11.1
i hope this helps
