10-24-2009 09:30 AM
i have to make a pattern projection in jpeg with gray code. We want to drive a sanyo projector with labview .
The projector has usb, vga and a rs232din(bt for this last we don't have the cable).
It's necessary to use VISA vi? It's possibile with vga?...i don't want to project my desktop but only jpeg pattern with labview.
Dan10-24-2009 09:37 AM
10-24-2009 12:07 PM
10-24-2009 01:32 PM
You need some vi to display the jpeg.
Modern systems even laptops often have the ability to control two screens, the primary and secondary monitor at the same time.
If you use the projector as second monitor you can display the jpeg on that screen.
So you have a cheap system, only need the vga cable and labview.
Think out of the box and your problem is solved.
10-26-2009 04:55 AM
I agree with Albert!
If you need some info about moving the front panel on the secondary screen, you can have a look at this.
Serena M.
