Jpeg projection with labview projector with vga or usb
i have to make a pattern projection in jpeg with gray code. We want to drive a sanyo projector with labview .
The projector has usb, vga and a rs232din(bt for this last we don't have the cable).
It's necessary to use VISA vi? It's possibile with vga?...i don't want to project my desktop but only jpeg pattern with labview.
Dan
(4,677 Views)
make the projector the second monitor, and use the vga cable.
make the vi filling the entire second monitor and off you go
(4,673 Views)
sorry but what you mean with "make the vi filling the entire second monitor and off you go
"?...Dont'you have any examples...i want to work with labview in my screen and project only some jpeg...
(4,661 Views)
You need some vi to display the jpeg.
Modern systems even laptops often have the ability to control two screens, the primary and secondary monitor at the same time.
If you use the projector as second monitor you can display the jpeg on that screen.
So you have a cheap system, only need the vga cable and labview.
Think out of the box and your problem is solved.
(4,648 Views)
I agree with Albert!
If you need some info about moving the front panel on the secondary screen, you can have a look at this.
Serena M.
(4,628 Views)
