I have a NCD DMF5003 LCD Display that communicates in ASCII. I am curious to know how to use VISA/SERIAL to do so, so I can send it text.
I can program the DMF5003 with no problem in VB6. I need to know the equivilent of CHR$(xxx) for LabVIEW 6i. I am dead in the water and any help will be greatly appreciated!
(3,787 Views)
There is an example on our web site that converts Decimal/Hexidecimal to its ASCII Character. You can find with the following path (I also attached them):
ni.com>>Technical Support>>Advanced Search...Check the Example Programs box and search for "decimal convert ascii"
If this is not what you are looking for, there are several example programs and resources available I suggest searching. Good Luck!
Best Regards,
Chris D
Nationl Instruments
(3,787 Views)
Thank you for you prompt response Chris. I will try these out.
(3,787 Views)
