looking for a manual for gpib232ct converter
I am trying to test a gpib232ct converter but I don't have a manual. At least I want to know which one of the 2 switches in the board control the baud rate and if I need a null modem adapter for this converter.
David
(3,073 Views)
Switches 1-3 are used to set the baud rate. The table below shows how to configure them.
Indication 1 2 3
OFF OFF OFF 300 baud
ON OFF OFF 600 baud
OFF ON OFF 1200 baud
ON ON OFF 2400 baud
OFF OFF ON 4800 baud
ON OFF ON 9600 baud
OFF ON ON 19200 baud
ON ON ON 38400 baud
You must use a null-modem serial cable (also known as a file transfer cable
or a DTE-to-DTE cable) to connect your computer to the GPIB-232CT-A.
The User Manual for the 232 CT-A can be found at the following website.
http://digital.ni.com/manuals.nsf/web_product_currentandold/DA5FD6FB10572F0B86256820006D1B00?OpenDocument
All of NI's product manuals can be found at the following site.
http://digital.ni.com/manuals.nsf/web/byproductcurrent&old
Kim L.
(3,073 Views)
