I have an older version of laview that is curently running on windows 3.0
Hi , i have an older version of labview and i'm currently running it with windows 3.0 .I would like to be able to load it on a machine with windows 2000 or windows NT, can i do this, if so how do i go about it.
Thanks Lennox
(3,217 Views)
The following knowledge base article mentions the version of LabVIEW compatible with Windows 2000:
Is LabVIEW Compatible with Windows 2000?
I think LabVIEW 5.0 is compatible with Windows NT. What's the LabVIEW version you're using?. You will also need to check if the driver versions (if you're using any) is compatible with the new OS.
DiegoF.
(3,217 Views)
