I like to convert from string format into array
I have problemwith function "spreadsheed string to array" and I need your help on that.I have to convert a string number (ex.:3,345E-02)into array. If I use function mentioned before, the results of conversion is 3.000E-02.The data were acquired from oscilloscope Agillent with deep memory, and the data type of file is .csv.
Primoz Bogataj
(3,955 Views)
how about wire the "format string" input of "Spreadsheet String to Array" to "%f" ??
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,955 Views)
Hi, i tried your example.
1) You have use dot instead comma as decomal point. (in your message written 3,345E-02)
2) In format string write "%f"
(3,955 Views)
