getting 10401 error
i am receiving 10401 from 'ai sample channels.vi' which is a sub vi of 'ai read one scan.vi. i have attached the application. thank you!
(3,452 Views)
Hello;
That error states the device your are poiting to the VI is not a National Instruments device.
That might be caused by different reasons:
- The DAQ device might not be installed properly
- The NI-DAQ might not be installed properly
- The support files for Labview might not be installed properly
Anyway, the first test for you to do is to test the board in MAX and make sure the board is working.
Hope this helps.
Filipe A.
(3,452 Views)
