I'm looking for a driver for a wavetek 195? Thnx in advance!
Or else: is it possible to use drivers written for other wavetek arbitrary waveform generators? Has anyone experience on that area?
(3,584 Views)
Geewee,
Below you find a link to a website which lists all drivers for Wavetek devices.
Keyword Search: Wavetek
I saw that the 195 is not listed. But you could take a look at the other drivers for arbitrary wavefomr generators. Normaly a manufacturer would not specify a whole new comand set for a new type of generator. The only thing that could change is new functionality which maybe is not available in your device. I have no experiance what so ever with this but you could give it try. other wise you can request the driver on the same website and hope that it will be available so
on.
RikP
Application Engineering
National Instruments.
Message Edited by Molly K on 02-18-2005 11:13 PM
Rik Prins, CLA, CLED
Software Development Engineer
(3,585 Views)
Thanks. I'll give it a try.
(3,584 Views)
