Hello!
I am currently trying to create an instrument driver for a Ballard "Nexa" fuel cell with the Instrument I/O Assistant.
The fuel cell data is 43 byte sent every 200 ms at 9600 Baud (8N1). I do have a working communication, because I can see the data coming in when I´m using an ordinary terminal program. The Instrument I/O Assistant however does not seem to receiver anything.
Here´s what I do / what I see:
- Create an empty VI
- Place an "Instrument I/O Assistant" block on the block diagram, the Instrument I/O Assistant windows pops open.
- Choose device: COM1 or COM2, depending on where the Nexa is connected (Choosing different devices has no influence on my problem)
- Add step "read and analyze"
- Click "Run this step" to read the data coming in from the serial port, but nothing happens until the the timeout set on the choose device tab has expired, then I get a timeout message (see attached picture).
I added a RS232 diagnostics plug that has blinking LEDs while data is flowing to make sure there is data coming in while the assistant is running.
I a previous thread, I read that the Instrument I/O Assistant has a bug concerning the locale settings of windows:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000002DBF0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=Instrument+I%2FO+Assistant+is+not+communicating&USEARCHCONTEXT_QUESTION_S=0
So I tried the same after switching my locale settings from german to english, but with no success, the I/O Assistant still seems to see not input.
Does somebody have another s
uggestion? Has anybody written a serial read/parse VI from scratch that he/she might share so I can use that as a starting point, if the assistant keeps failing for me?
Thank you,
Ingo.
