Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
I'm unsure when configuring a RS485 interface as two wire, which wires it uses?
Kowalski
Member
09-03-2007
09:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When configuring as two wire auto, does the RS485 Unit connect the TX and RX lines internally or do you have to do it externally?
0
Kudos
Message
1
of 2
(2,994 Views)
Reply
Re: I'm unsure when configuring a RS485 interface as two wire, which wires it uses?
Brian_Beal
Active Participant
09-03-2007
03:35 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You don't state what hardware you are using, but any 4-wire RS-485 device I have used in 2-wire mode required me to physically tie the lines together.
0
Kudos
Message
2
of 2
(2,988 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
