I need an IVI-Driver for a Tektronix TDS 5000
IVI-Scope steptypes from TestStand require an IVI driver for the TDS5000. Any help ?
(4,043 Views)
The driver is not available now, but should be available on the begin 2003. Try use tktds7x4, the command set should be same from 90%. Only ranges will be different. Try use it. For sure try disable cache. If your application will required any ranges which are out of range for this driver. Disable range chacking too. I wrote this driver, so if you will have any troubles, let me know.
Zdenek
(4,043 Views)
Driver for tktds7x4 is available on http://zone.ni.com/idnet97.nsf/browse/
(4,043 Views)
Hi firly,
If you are still interested in IVI driver for TDS5k series, please send us your contact information at instrument.driver@ni.com.
Instrument Driver/IVI group
(4,043 Views)
