The driver is not available now, but should be available on the begin 2003. Try use tktds7x4, the command set should be same from 90%. Only ranges will be different. Try use it. For sure try disable cache. If your application will required any ranges which are out of range for this driver. Disable range chacking too. I wrote this driver, so if you will have any troubles, let me know.
Zdenek
