I need help trying to use a hp4277a LCZ meter
I was wondering if anyone knew of a place i could get some instument drivers for hp4277a LCZ meter. I want to write a program with labview 6i. if anyone can help it would be greatly apprieciated
(3,492 Views)
There is a driver for the 4276 LCZ meter in the Search Instrument Driver Downloads section. It will probably do most of what you want to do. Use that as the start, and modify the code with the manual for your meter.
(3,492 Views)
great will try that. thanx. do you know if there is any sample vi for it.
(3,492 Views)
