I need the equivilent of Hello World for a C program that calls a GPIB instrument over VISA.
I have VISA installed.  I also use LabVIEW all the time for automated programs.
But today I want to create a simple C program that uses VISA to send an *IDN? command to an instrument, and then reads back the result.  This is the hello world program that will get me off the ground.
I have no idea where to start in terms of setting up the C variables, which functions to call in which order to establish a VISA connection so I can send my command and read the results.
I did some searches, but did not find any good matches.
I am going to write this C code in Dev-C.  (I do not have LabWindoes.)
If it helps, my motivation is to create a very small executable that I can use to make simple measurments.  For complex tasks, I use LabVIEW.  But LabVIEW is overkill for some simple tasks.
I appreciate any help from someone who knows how to do this without even thinking.  Thank you in advance,
Mike
(3,945 Views)
Hey Mike!
How are you doing?  If you have the drivers installed, you should have examples in different programming languages in the following directory:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-VISA\Examples.
These examples should get you started!
Best Regards,
Song Mu
National Instruments San Diego
(3,928 Views)
Hi Song,
Well, I knew what I was looking for must be out there somewhere.  But is nearly overwhelming to start looking...  : )
The path is slightly different, but the example here:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-VISA\Examples\C\General\RdWrt.c
is what I was looking for.
For anyone else doing this with Dev-C++, I downloaded version 4.9.9.2 from the internet, and it installed with no issues.
I then created a new project, and added the above example file "RdWrt.c" to the project.
I set the project type to console, and I selected "C" program, not C++.
I had to change the # include visa.h to be  #include "C:\VXIPNP\WinNT\include\visa.h"  (Is this the right way to do this?  It works...)
Then I added the library to the linker by selecting Project -> Project Options and then the Parameters tab in the dialog box.
The press the add libarary or object button, and I selected the path C:\VXIPNP/WinNT/lib/msc/visa32.lib  In this case, the msc library worked for me in Dev-C++.  I don't know if this means all of needed VISA functions are now available to me or not.  But so far this works.
Next select Execute -> compile, followed by Execute -> run.  And this works.  Smiley Very Happy  You have no idea how good it feels to reach this point.  I estimate it took me about 2 days, with many wrong turns, and with a lot of internet reading before settling on Dev-C++ as the IDE.  At this point, I have a "hello GPIB instrument" executable, and I think I will be able to do whatever I need to from here.
I hope this is useful information for others.  And thanks for your help.
Mike
(3,919 Views)
Glad I could help!
Best Regards,
Song Mu
(3,909 Views)
