I regret to say that my problem is not solved Iam unable to read the set of values(double) from the Agilent 4278A capacitance meter into LabVIEW through VISA using HPIB of Agilent.I will be glad if you could semd me the example showing the above
I unable to read a set of values(double) from Agilent 4278A capacitance meter interfaced to LabVIEW through HPIB card from Agilent,though Iam able to read status byte and send Device Clear command.I will be glad if you could send me an example showing tha above.The resource name Iam using is GPIB0::4::INSTR.
Thank you
Raghu.
(3,319 Views)
Construct the VI shown in the attached picture. You'll need to use the appropriate string to query for the data. If you do not know what string to use then contact Agilent support or consult your user manual.
(3,319 Views)
