The "ibwrt32" GPIB command doesn't understand string commands
I want to drive a 450 gaussmeter from Lakeshore. The used language is Visual Basic by the way of excel.
A part of my program is:
Dev1=ibdev32(0,12,0,T10s,1,0) 'this line is OK'
call ibclr32(dev1) 'This line is OK'
call ibwrt32(dev1,"ZCAL",4) 'my problem is there'
"ZCAL" is a typical gaussmeter function which makes zero and coded on 4 bytes. If I write this line the zero is not made. However, if I used the NI program "Measurement and Automation" to communicate with my instrument, when I write ZCAL the command is executed and the buffer indicated in "NI Spy" software is 5A 43 41 4C corresponding to z c a and l hexadecimal codes.
Now if I return in my program and write the following command:
call ibwrt32(
dev1, &H4C41435A ,4) the ZCAL command is executed on the gaussmeter. The command is also executed if I write the decimal code of "ZCAL"
So, my first question is :
Why my program doesn't understand the command in the string form "ZCAL"
My second problem is to execute commands coded with more than 4 bytes. For example, I use a comand named "MAX 1" coded on 5 bytes. On Visual Basic, I don't have a data type coded on 8 bytes which could permit to resolve the problem. So, I can just execute command with less than 4 bytes.
(4,079 Views)
What shows up in NI-Spy when your ibwrt32 call fails? Try running an example program. Example programs are installed with the driver and are located at:
c:\Program Files\National Instruments\NI-488.2\Languages\Visual Basic
Excel is probably causing the problem. Ibwrt accepts any string and it does not matter how many bytes it has so I am not sure what 4 and 8 byte restrictions you are referring to. Try using the example program DMMsimple located in the directory listed above.
(4,079 Views)
Thank you for your advices. I've tried to run Example program and these programs can't be executed with excel. So, I obtained the MSVisual Basic software and the problem is resolved.
Best regards
(4,079 Views)
