I've got a GPIB card from hewlett Packard to use with a HP4263A LCR meter
I've got a GPIB card from hewlett Packard to use with a HP4263A LCR meter, I am trying to use NIDAQ to get the data in labview,but the card is not detected, what can I do? I am using an AT-MIO-16E card and a PC-DIO 32 card, installed by another developer, I just would like to get the device working again, but I do not have any experience with labview.
(3,087 Views)
Hello;
It's not clear from what exact device you are willing to get data. By what I understood from your e-mail, you are intending to get data from the HP GPIB board. If that is the case, you don't need NI-DAQ. You will probably be better of by contacting HP and ask then for the Labview driver for that GPIB board.
Regards
Filipe A.
(3,087 Views)
