Why won't my NT/P3 system seem my GPIB card?
It doesn't appear to be using a IRQ already assigned, the jumpers are right, and it works in another machine running NT just fine. Any ideas? I'm using the default memory location (0x2c0), and have tried de-selecting DMA. The CPU is a P3 HPVectraVL 500Mhz.
(3,124 Views)
Hello Dennis,
First, check here
http://www.ni.com/support/gpib/versions.htm
to make sure you are using the right version of NI-488.2.
From your description, it sound like you are using an AT-GPIB or AT-GPIB/TNT (non-Plug&Play) card. Before you insert the card into the computer, you should be going into MAX, right clicking Devices and Interfaces and selecting Create New>>gpib interface>>... The software will tell you what the jumper settings should be and will give you screenshots. After setting the jumpers, just shutdown the computer, and put in the card.
(3,124 Views)
