I want to truncate numbers converted to integers.
How do I do this?
(4,546 Views)
Depends on what you want to do. Which part of the number are you truncating (can you give an example?). What programming language are you using?
(4,546 Views)
I'm using LabVIEW. I want to truncate the fractional part of a number. For example 9.71258 would become 9 when converted to an integer.
(4,546 Views)
LabVIEW has a set of conversion vi's under Functions->Numeric->Conversions that will take floats and covert them to integers. This will truncate the fractional part. In addition, LabVIEW can automatically cast numbers to the appropriate type - when you connect a float number to a vi that takes a U8 input for example.
If you don't want to do a conversion, you can use the "round to nearest", "round to +infinity" (ceiling), and "round to -infinity" (floor) functions which will truncate/round floats.
(4,546 Views)
Thanks. You've been very helpful. The "round to - infinity seems to work. I had tried the conversions and they seem to round the number rather than truncate. I'll use the "round to - infinity".
(4,546 Views)
