ID query -1074003951 with pressure Calibrator
Hello everybody, I´m trying to use a LV driver for a DPI515 Pressure Calibrator.  I downloaded this driver from the Druck download page. I got error -1074003951 from de Init.vi
I´m relative new to LV, but I know he´s trying to query its ID. The problem is the following: I have to uncheck and try to run it. Then I get this error. Then I check it back and try to run it twice. On the second time I don´t get an error, and the Get_Started.vi works perfectly. When I quit this VI and try to run the Init.vi again, i get the same error. I saw in the NI SPY, that the *IDN? string is reading "UNIT:PRES MBAR", instead of course of its ID (*IDN DRUCK, DPI515....). Obviously I´m writing before the *IDN? string before reading it. Anyone any ideas?
I´m using LV 8.0 and this driver was developed with LV 6.0 (says on Druck´s Internet page). Comm: RS232 VISA serial (9600/ none/ none/ 8 bits = for LV and the device).
Thanks in advance
Edgar Charry
(4,444 Views)
Hi Edgard,
Have you tried to contact Druck to solve this problem? They must guide you on this issue. Also take a look at that driver's manual to find out how it must be handle.
Fernanda Silveira.
(4,356 Views)
There might be 'old' characters in the buffer from a previous query.  In the Initialize VI, it is possible that adding a VISA Clear after the VISA Open will solve your problem (see referenced Initialize template VI below).  Another thing to try is inserting a VISA Read before sending the *IDN? command.  This will read any old contents out of the buffer.
I have not looked at your driver, but you can try to take a look at the Initialize VI from the instrument driver templates that install with LabVIEW:
...\LabVIEW 8.0\instr.lib\_Template - Generic\Public\Initialize.vi
There is also code here that flushes the serial buffers that might be helpful for you.
At a worst case, you can disable the ID Query.  However, the 'old' data will still exist and eventually be returned as part of a future read.  If you got the driver from Druck, it would be a good idea to report the issue so they can fix it and prevent future users from experiencing this problem.
(4,346 Views)
