crash in ni488.2 ibrd
I've written a LabView-callable DLL that calls the ibrd() function to retrieve 1601 complex points (X4) from an 8720, it works well from my 1.6 GHz Core 2 Duo laptop but crashes randomly from P4 machine running around 3 GHz.   How do I fix this?
   ...Dan
(3,378 Views)
Hello dgholstein,
Is there a reason why you are not using the built in GPIB Reads or VISA Reads for your LabVIEW application?  They interface directly with the gpib-32.dll and also make a call to ibrd().
This Knowledgebas goes through many of the reasons why LabVIEW would crash because of a dll call.
Let us know if you find the problem or if you are able to eliminate the possibility of one of these problems.
Steven T.
(3,351 Views)
Yes, the reason I wrote my own in C is because I need speed and I need (freely available) scientific libraries for processing the data quickly.  Besides, LabView calls those same DLLs, why can't I do the same?
I did finally figure out why it is crashing (or more accurately, I figured out how to stop it from crashing).  This old programmer figured he'd be conservative and declared the buffers in global, when I moved the buffers to local variables, it stops crashing.  I understand modern OSes and compilers merely allocate new memory for local variables for every entry into a DLL (often putting that on the stack, too).  I learned this when making adjustments to my codes in order to make them reentrant.
I would hope I could re-use statically-declared global memory space as buffers, I can live with the (less-efficient) alternatives.  I hail from a time when CPU time and memory had value (and you'd actually look at compiler reports).
   ...Dan
(3,345 Views)
