ISA PCII/IIA GPIB Card and Windows XP
Is it possible to get the PCII/PCIIA (488.2) ISA GPIB card to function in Windows XP Pro? Drivers in use are 1.70 but in device manager when add hardware util is used the device gives "error 10 cannot start" even though IO config etc. is manually set to match that of the card.
(3,523 Views)
This card is not supported in Windows NT4, 2000, or XP. You may upgrade your card by visiting the following web page: http://www.ni.com/support/gpib/upgrade.htm
(3,523 Views)
