IVI Configuration with PXI-4110 in TestStand
Hello All,
Set-Up:
PXI-1033 connected through MXI to a PC running Windows 7. LabVIEW 2014. TestStand 2014 (32-bit). PXI-4110 Power Supply and PXI-4070 DMM.
In MAX I can open both soft panels and control both units and they work great.  In LabVIEW I can control both cards as well.
In MAX I have set up a driver and logical name for my DMM. This unit works great within TestStand using an IVI DMM step.
I then proceeded to setup the 4110 in MAX with an IVI driver and logical name. Here are my settings:
Hardware: Added hardware asset and select the PS. This one is checked, no other assets are checked.
Software Module: NI-DCPower, 4110 is listed as a device that is supported.
Virtual Names: This is where I am confused, Under physical name there are four options that come up (0, 1, 2, and 3). This power supply only has 3 outputs so I am unsure why four come up. I have made 4 virtual names, one for each of the options. I named them ch0, ch1, ch2, and ch3 respectively.
When I put an IVI Power Supply step in TestStand everything seems to be working. I open the configuration window and set my values for each channel. If I try to validate the setup by unchecking simulate and click on init I do not get an error.  As soon as I clic on 'Configure' or 'Show Soft Front Panel' I get the following error:
"The IVI Configure operation failed for lgical name 'NI PS 1'. Details: Extention capability not supported by instrument driver. (Base) (-30717)"
Any information would be appreciated.  I tried playing with it for a couple hours yesterday and had a couple co workers try to help.  We are all under the assumption that this should be working.
Thank You!!
Jesse
(5,138 Views)
Accepted by jesserzamora
Hi jesserzamora,
Have you seen this link: http://digital.ni.com/public.nsf/allkb/331F2717DBCD1F858625758200745773?OpenDocument
It discusses a similar failure with the IVI Power Supply step in TestStand.
Julia P.
(5,097 Views)
Thanks so much.  I hadn't seen this article. This helped me solve my problem.
Jesse
(5,093 Views)
