IVI DMM, SWITCH, SCOPE all crashing LV24-64bit
Has anyone sucessfully used the IVI DMM on LabVIEW 24-64bit? I have ICP v24 installed and NI-DMM v23Q3.
If I drop IviDmm Initialize.vi on a blank VI it instantly crashes LabVIEW. Same happens with NI-SWITCH and NI-SCOPE VIs...
(639 Views)
Update: It's likely SentinelOne antivirus.
(583 Views)
Accepted by sharpen
Confirmed SentinelOne was causing the issue. Saw a similar crash dump to this Troubleshooting LabVIEW Executables: Addressing Crashes with Sentinel One Antivirus
(558 Views)
I have the same issue here, did you find a solution except disabling SentinelOne?
(432 Views)
No, had to have corp. IT whitelist. Not sure exactly what they did but the problem went away.
(407 Views)
Ok thanks, we'll give it a try.
(395 Views)
