IVI DMM, SWITCH, SCOPE all crashing LV24-64bit
Has anyone sucessfully used the IVI DMM on LabVIEW 24-64bit? I have ICP v24 installed and NI-DMM v23Q3.
If I drop IviDmm Initialize.vi on a blank VI it instantly crashes LabVIEW. Same happens with NI-SWITCH and NI-SCOPE VIs...
(559 Views)
Update: It's likely SentinelOne antivirus.
(503 Views)
Accepted by topic author sharpen
Confirmed SentinelOne was causing the issue. Saw a similar crash dump to this Troubleshooting LabVIEW Executables: Addressing Crashes with Sentinel One Antivirus
(478 Views)
I have the same issue here, did you find a solution except disabling SentinelOne?
(352 Views)
No, had to have corp. IT whitelist. Not sure exactly what they did but the problem went away.
(327 Views)
Ok thanks, we'll give it a try.
(315 Views)
