IVI Drivers : RangeCheck initialization option true : Unable to get an out-of-range error
Hi there,
I'm new to IVI drivers (started using them last week) and I have a problem with the RangeCheck initialization option.
In order to get used to IVI drivers, I used the example that comes with the IVI-COM AgilentE36xx driver (on my computer it's located at C:\Program Files\IVI Foundation\IVI\Drivers\AgE36xx\Examples\VS.NET\Cpp\Example1).
I have been able to do all I wanted except getting an out-of-range error when passing an out-of-range value to a function. I set the RangeCheck init option to true but I did not get any error in simulation neither with the hardware connected.
Attached is the code (from the Agilent example) but modified in a way that it should throw an out-of-range error when setting the voltage at the following line: spOutput1->VoltageLevel = 1000; // ... why no error.
Still it's executing fine. Can anyone point me to what I'm not doing correctly.
Romain
(4,365 Views)
It probably depends to what extent the range checking feature is implemented in the driver. National Instruments does not support Agilent IVI-COM drivers so it would probably be better if you ask Agilent for help. I am not sure which exactly model you use but NI provides these two IVI-C drivers:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E91E8659CE034080020E748...
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E90F3659CE034080020E748...
(4,351 Views)
Hi gagi1,
Thank you for your answer. Yes, I will contact Agilent.
In the meantime, do you have any example of C/C++ code (using IVI-C or IVI-COM drivers from NI) that throw an out-of-range error?
Regarding the links in your reply, I think the drivers are either for LabWindows/CVI or for LabVIEW. Unfortunately, I use C/C++ as ADE.
Romain
(4,346 Views)
Accepted by NIIVI
I posted the question on the Agilent Forum.
Here is the link to the post: http://www.home.agilent.com/owc_discussions/thread.jspa?threadID=33348&tstart=0
The problem is now solved. Thank you for your help.
Romain
(4,327 Views)
