03-22-2010 01:29 AM
Hey,
Can anybody get me IVI drivers for Fluke 5700A multi-function Calibrator.
It will be of great help.
Thanks in advance.
03-22-2010 03:06 AM
Hi
If you are programming in LabVIEW you can better use the existing plug and play or project style driver.
Easier to debug and better readable than most IVI drivers.
Although I really like the IVI concept of replaceble drivers, most are black boxes that are difficult to debug.
If you are not programming in LabVIEW yet maybe someone should create a c interfaceabove such a LabVIEW driver.
Easy and maybe even possible in IVI style.
03-22-2010 02:08 PM
Thanks for replying.
Actually we have two calibrators 5700A, as well as 5720A. So, it will be highly beneficial for me to use IVI drivers. We can use the single piece of software for both instruments using IVI.
That's the main point.
03-22-2010 04:22 PM
So I assume you have already an IVI driver for the other machine.
If the commandsets are not to different it is also easy with a LabVIEW driver.
And I have mixed all kind of instruments in LabVIEW with a self defined API and then calling the plug and play driver.
Just a small skin over the existing driver is close to the IVI philosophy.
03-24-2010 01:13 PM
Thanks again for replying.
Can you post me any examples, it will be of great help. Actually, I am new to this stuff.
03-25-2010
09:30 AM
- last edited on
04-03-2026
08:53 AM
by
Content Cleaner
Hello Ishank,
This example and paper has some good ideas:
How to Mitigate Hardware Obsolescence in Next-Generation Test Systems\
Cheers,
NathanT
03-25-2010 11:37 AM
03-25-2010 12:59 PM
03-26-2010 01:35 AM
@Albert
Yes, I have IVI drivers for other machine.
03-26-2010 01:48 AM
