04-05-2010 02:10 AM
I am not able to install IVI specific drivers in LabVIEW 8.0.1.
The drivers I want to use are for fluke 8846a, 8508a and 5720a.
The setup of these IVI specific drivers does not give an option to install for labview version 8.0, it is giving option to install on versions 7.1, 8.2, 8.5 and 2009.
Please help.
Solved! Go to Solution.
04-05-2010 07:58 AM
Hello ishank,
That is the expected LabVIEW support for the previously released IVI Specific Driver installers (the currently released installers only support LV 8.2 and higher). You can just copy the LV 7.1 files over to the LV 8.0.1 directories and then mass-compile the VIs.
Cheers,
NathanT
04-06-2010 06:18 AM
