The Error Generated is 6(NO QUERY), which indicates that the computer addressed the supply to talk, but did not first request data according to the instrument manual. I have now discovered that the error is set in the power supply when a subsequent instrument is configured. This can be observed by configuring a DMM after the power supply. However, if the DMM is configured before the PS and then READ after the power supply and before another instrument is configured the error is not generated. It seems like the GPIB address change is not immediately recognized by the 6624A power supply. Has anyone seen similar problems using this IVI driver? I never see this problem with the 6610X power supplies.
