Identifying PXI properties to decide whether to route triggers on PXI bus segments
I have a PXIe-1075 and a PXIe-1062Q chassis.  Each has a similar card configuration.
I initially developed my application for the PXIe1062Q chassis, routing a trigger from the timing card signal generators and a digitizer.  When I run it on the 1075 chassis, I have to route the triggers from bus segment 2 to bus segment 1 so that the triggers from the timing cards reach the digitizers and signal generators. On the 1062Q chassis, this isn't necessary since everything is on the same segment.
I have used the article Programmatically Routing PXI Trigger Lines Across a Multi Segment PXI Chassis to successfully route my trigger.
Is there a way to identify how many bus segments I have, or what chassis I am using, so that I can automatically connect the triggers (or not), so that I can use the same VI to control both hardware configurations?  I don't know what happens if you try to connect triggers across bus segments that may not exist, but I wanted to know what the correct way to deal with this situation is.
(3,653 Views)
Accepted by gregoryng
You could pull the trigger bus number using NI VISA.  Just give your devices a VISA alias in MAX and you can use a VISA property node to pull the PXI trigger bus number.  This should help you out.
Best,
Adam
Academic Product Manager
National Intruments
(3,635 Views)
Thanks, that makes sense.  I bet that will work.
(3,631 Views)
Yep, this worked.  It took me a bit to figure out where to name the alias (as it already had a DAQmx alias), but this worked exactly as I wanted.
(3,535 Views)
