05-05-2009 05:57 AM
The terminators I talk about are at the RS-485 interface NOT at the RS-232.
So the active terminator should be places inside the RS-232-485 converter.
But your problem is the change of the RS-232 interface. So....
But do check the active terminator at the RS-232-485 converter side. Changing the RS-232 interface can be of influence on the ground level of the RS-232-485 converter.
A active terminator are 3 resistor in series connected between Vcc and ground. From Vcc to ground it is 390Ohm + 150Ohm + 390Ohm. The 485 lines are connected across the 150Ohm. A(+) on the Vcc side.
05-05-2009 06:00 AM
To be more accurate, here's the result of my testing. I'm out of idea.
| Testing Result |
Meter |
IO Board |
Converter A |
Converter B |
Converter A |
Converter B |
On Board COM Port |
-O.K- |
-O.K- |
Time Out and Illegal Response |
-O.K- |
PCI Extended COM Port |
-O.K- |
Illegal Response |
05-05-2009 06:05 AM
05-05-2009 06:10 AM
OK, I will think about it and see if there is something else I can come up with.
Meanwhile I have my own troubles with a UM232 (USB) to RS-485 converter. I get two extra null bytes before the data but not always. No idea where they are coming from....
Bad time of the year for RS-485 data transfer I think ![]()
