Image received from visa is shifted in some lines . Can anyone help me ?
Image received from visa is shifted in some lines, any suggestions ?
Message 1 of 12
(5,264 Views)
From this info, nobody can say what is wrong.
Provide instrument, vendor, bus, software etc.
Message 2 of 12
(5,245 Views)
I converts the image into ASCII type and send it through Visa , then received the ASCII data and convert it to the corresponding  pixels Value ant Bitmap it with the same dimension of the source image ,but image is shifted in some lines of pixels and it happened with all Pictures at the same lines.
Message 3 of 12
(5,217 Views)
You still aren't making much sense. No one has any idea of what image, how you are converting, how you are tranmitting, reading, etc.
Message 4 of 12
(5,213 Views)
like ... interlacing?
Message 5 of 12
(5,205 Views)
Yes, like this image but, only on specific lines
Message 6 of 12
(5,198 Views)
like this one
Message 7 of 12
(5,197 Views)
Since you are unwilling to provide any details, I can only conclude that you are not interested in getting your 'problem' solved. You have not provide any information except the statement 'it does not work'. You don't even want to tell anyone what programming language you are using.
Message 8 of 12
(5,193 Views)
Trigger problem, maybe?
Details, dude.  You're not very good at helping us help you... devices, interfaces you're using, how you're taking that data... anything would help more than what you've given us...
Message 9 of 12
(5,186 Views)
Message 10 of 12
(5,126 Views)
