Impedance Analysis with the Keysight E5061B Network Analyzer with Labview
Hi everyone,
Hope you all doing well,
I need to configure and measure impedance in E5061B analyzer using labview, i have some scpi commands and .VBA file i dont know how to use them
can anyone guide me how to measure impedace,Z-parameter
scpi parameter:http://ena.support.keysight.com/e5061b/manuals/webhelp/eng/programming/command_reference/command_fin...
Thanking you,
Venugopal.
Venugopal
Message 1 of 8
(7,733 Views)
Use Help> Find Instrument Drivers. At http://www.ni.com/downloads/instrument-drivers/ you'll find links that explain what a driver is and how to use one.
Message 2 of 8
(7,726 Views)
American test engineering jobs going overseas by the boatload to India, and we have to help them figure it out?
Message 3 of 8
(7,716 Views)
Dear sir,
I have already downloadded the drivers but i can't find a vi to measure impedance
thanking you,
VenuGopal
Venugopal
Message 4 of 8
(7,698 Views)
Dear sir,
Test engineer jobs can you send me some details
thanking you,
Venugopal
Venugopal
Message 5 of 8
(7,695 Views)
Have you run the example that comes with the driver?
Message 6 of 8
(7,682 Views)
Yes i checked thew examples there is no vi provided for Z parameters
Venugopal
Message 7 of 8
(7,677 Views)
Accepted by topic author VenuGopal@57
Start with setting the instrument up manually and pay attention to the front panel settings of the instrument. You should be able to map those to SCPI functions. The driver can be searched for those functions. Make sure you ave Context Help turned on. If you don't find a driver function that does exactly what you need, you have the source code.
Message 8 of 8
(7,674 Views)
