Implementing HMI/ SCADA for AB Micro830
Hi guys,
I am a doing my final year thesis on programming AB Micro830 for basic water rig process. My lecturer would like me to create a HMI / SCADA for it on a computer so that future students can view the flow rate of the water / water level / change the setpoints. I am wondering if anyone can give me a guideline on what software should I use to implement it? Thanks.
(5,064 Views)
anyone?
(5,053 Views)
Hi THED,
The LabVIEW Datalogging and Supervisory (DSC) Module is an add-on to LabVIEW and is specifically used to create HMI/SCADA data-logging applications.
Hope this helps,
Allison M.
ni.com/support
(5,048 Views)
Hi, is this software compatible with Micro830? What I am trying to achieve is to be able to view the water level and change the setpoint via the hmi. Thanks,
(5,020 Views)
Did you look at the above link? There is a link on that page to this about PLCs.
(5,016 Views)
 I will get back to you with my progress. Time to catch up with my other units other than thesis now. Does programming / making HMI require any special programming language skills? I am new to this and have no time to research this can you just give me a brief run through on what is required. I really appreciate it. 😃
(5,003 Views)
You would need to learn LabVIEW if that is what you choose. Obviously, you need to know how to program the plc. You will need to find the time.
(4,999 Views)
