usb 485 "unknown device" in device manager.
Hello all,
I have just connected a USB-485 to a test PC.
Sadly the computer does not recognize this device in device manager.
Next I connected it to my laptop, this also was no succes.
The computers have Win Xp on then SP2.
I also deleted ni-serial, rebooted, installed ni-serial again, no succes...
Who can help me, is the usb-485 defect?
Message 1 of 8
(4,607 Views)
Who makes the device? Unless it is NI, installing Ni-Serial is a waste of time. You would need driver from the vendor.
Message 2 of 8
(4,604 Views)
Ow sorry,
It's the USB-485 from NI ofcourse.
Message 3 of 8
(4,599 Views)
Generally with these devices, you must install the software first and without the device connected.
Then reboot the PC.
Message 4 of 8
(4,591 Views)
Did that also but it stays unknown.
Message 5 of 8
(4,581 Views)
try a different USB port?
you do have the power supply plugged in for this device?
Message 6 of 8
(4,575 Views)
Hello darkcxeed,
Can you post a MAX Report of your system so that we can check which software and software version is installed on the system?
http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4?OpenDocument
Can you also post some more information about the pc itself?
http://digital.ni.com/public.nsf/allkb/DDF39729A407BFC1862578F7007807A3?OpenDocument
Did you delete or uninstall NI-Serial?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 7 of 8
(4,558 Views)
In addition to what Thierry requested, could you look at the properties of the "Unknown Device" in Device Manager, and see what "Hardware Ids" are present? It would be good to plug and unplug the interface a couple times, to make sure it is associated with the unknown device.
Here is a sample of what the Hardware Ids will look like in Device Manager:
Message 8 of 8
(4,543 Views)
