‎08-02-2010 05:03 PM
I recently created a new IVI driver for a 5412 NI-Fgen card in MAX. I am unsure of how to implement this driver into labview, however. Can anyone point me in the right direction?
Eric
Solved! Go to Solution.
‎08-02-2010 05:21 PM
If you configured MAX for the NI driver then use the IVI Function Generator class driver on the Instrument I/O palette.
‎08-03-2010 09:27 AM
Thanks Dennis, that is what i was looking for
‎08-03-2010 03:01 PM
Hi again,
I think i figured out how to generate a signal using the IVI drivers. My problem now is that I have no way to observe this signal. Is there a tutorial somewhere that I can follow step by step to solve this problem?
Eric
‎08-04-2010 09:41 AM
duplicate post - reply posted here
