Infinity 1-1c camera control with labview
Hi Everyone,
Recently, I try use labview to control my camera (Infinity 1-1C). I installed 2010 labview plug-in for camera, and my labview and vision was 2013 at that time. When I tried ran the Snapshot example VI, the warning said the data types are different, please see attachments. Then
I installed labview 2010 version instead of 2013 version, the problem is solved, the run arrow not broken again.
What's the difference between labview 2010 and labview 2013, why the 2010 version is compatible with 2010 plug-in for camera, 2013 version isn't compatible?
Anothering thing is the technician told me NI company wrote this plug in. so I have a detail question about the snapshot example in this plug in. When I ran this example in labview 2010 with grayscale image format setting, the programming works, and I got image. But when I set the image format as 32 RGB since Infinity 1-1C can get colorful image with 32 RGB, the programming gave a error. The error said: 5100 occurred at LvLuConvImg.vi. So I opened LvLuConvImg.vi, and changed the Bayer setting, but it still not works.
Would you please give me some suggestions about these questions in detail? That's would be very helpful.
Thank you very much, and I really appreciated it.
(5,176 Views)
Thank you for posting on our forum. If you are referring to NI-IMAQ, there are compatibility issues related to different versions of LabVIEW. As LabVIEW versions change, incompatibilities can become an issue when it comes to drivers and plug-ins. You can find the chart that details compatibility between NI-IMAQ and LabVIEW here.
I wanted to let you know that I have redirected this question to a team member that has more experience with our vision software.
Warm Regards,
Josh
(5,146 Views)
