where can i find ni4882.h for gcc compiler?
I have c code compiled on MS visual Studio 2010. Now I need to recompile same code with gcc. But I think ni4882.h is not being linked correctly. Where can I find ni4882.h for gcc compiler? I am using MingW on my windows 8 PC.
(5,170 Views)
Why do you think, that ni4882.h isn't linked correctly ? Are there error messages ?
Correcly spoken ni4882.h  isn't linked. The header file is included by the preprocessor into the source code before running the compiler.
And later the library ( .lib file ) is linked  to the objectcode generated by the compiler. But you will usually need to specify on the compiler command line which library needs to be linked . And maybe also where to find the library ( IIRC gcc uses the -l and -L switches for that purpose)
(5,151 Views)
I am getting errors like these:
 undefined reference to `SendIFC@4'
 undefined reference to `Ibsta@0'
 undefined reference to `FindLstn@16'
 undefined reference to `Ibcnt@0'
 undefined reference to `DevClearList@8'
 undefined reference to `SendList@20'
 undefined reference to `Receive@20'
Can you suggest what should be right approach to compile my c code with gcc?i thought i need right ni4882.h for gcc compiler.
(5,142 Views)
I found some older forum posts that I think might be of interest. I hope it helps.
How Can I Use The NI-DAQmx ANSI C Function Library With GCC (on Windows)?:
http://forums.ni.com/t5/Multifunction-DAQ/How-Can-I-Use-The-NI-DAQmx-ANSI-C-Function-Library-With-GC...
- Kale
(5,107 Views)
