Information required for communicating with IEEE-488 Interface instrument.
Dear All,
I have an instrument which has IEE-488 interface. I would like to connect this to my laptop using GPIB USB connector from NI.
In order to communicate with this device and record data i have a licensed version of LABVIEW. But when i got in touch with NI salesperson i was told the connector would cost me Rs. 40000/- including software as indicated in web.
Question 1 - Is it necessary to purchase the software along with connector ? or can i manage to read it through LABVIEW?
Question 2 - I have read that the instrument manual and it can be programmed using IEEE-488.2 interface using LABVIEW measurement and automation explorer  can i do this using the existing LABVIEW.
Looking forward for an answer.
Srini
(4,002 Views)
Accepted by Yamata
Hi
if you have LabVIEW and NI GPIB hardware the VISA software is free.
Which instrument (model and vendor) are you trying to communicate with?
(3,999 Views)
Many thanks for the reply.
I am trying to communicate with temperature monitor from Lakeshore cryotronics. As per the manual, Programming is to be done using QUICK BASIC.     Is it mandatory or i can use LABVIEW to program the instrument.
Srinivas
(3,998 Views)
LabVIEW is used over here in all those places.
LabVIEW is a full blown programming language with a perfect support for instrument control, where VB was designed (or better grown) by non programmers.
LabVIEW itself is also a parallell programming language so doing stuff on the UI can run in parallel with other tasks without having to program a lot of stuff just to keep your program running.
In fact LabVIEW was original designed for users of gpib that were not used to program.
(3,995 Views)
Thanks for the reply.
How about connectors from other vendors. Does LABVIEW support connectors from any company or NI only.
I got this doubt just after looking a series of vendors who supply similar connectors.
Srinivas
(3,993 Views)
some connectors from other vendors will also work but with additional difficulty, for the agilent gpib-usb it is possible via an extra visa plugin.
For others it is also possible but using the standard instrument drivers like this one for Lake Shore (620/622 and 647)
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9473659CE034080020E748...
are readily available free of charge, and are tested by a lot of users.
(3,990 Views)
